    M106 - Feature Request, Limit MAX PWM parameter
    Firmware wishlist
    • gen2eng
      gen2eng last edited by
      It would be nice to have a M106 parameter similar to L that would limit the maximum PWM value for a fan.
      Usage:
      • I was brain dead and discovered 2 hours into a 12 hour print that I really don't want to run my fan as hard as it is to minimize heat rise in the motor. A quick command in the console saves the day to cap the maximum value.
      • Fan needs to be limited in an office environment with several newbies who are learning. Once again, brushed layer fan only wants to be run at 80% for extended period to times to reduce heat.
        You can define the layer fan speeds in the slicer. Isn't that sufficient?
        • gen2eng
          Yes, and limiting the max PWM is to mistake proof and protect against damage.
          It would be more applicable to brushed motors than brushless motors
            I have added this to the firmware wish list, however it will be low priority unless more users want it.
            gen2eng wilriker 2 Replies Last reply Reply Quote 0
            • gen2eng
              gen2eng @dc42 last edited by
              @dc42 Thank you!
              • wilriker
                wilriker Moderator @dc42 last edited by
                @dc42 So here is another user (me) M106 Maximum Fan Speed Setting - that just missed this thread. 😉
                Manuel
                My Tool Collection
