    New firmware 2.0RC5 available
    Firmware installation
    23
    88
    12.7k
    • sigxcpuundefined
      sigxcpu @dc42
      @dc42 OK, I will not take this then 🙂 I've already did it, but I couldn't manage to configure IDE for RTOS branch. Compiled 1.21 without issues, but 2.0 is not compilable yet (used v2-dev branch in both ReprapFirmware & CoreNG, imported DuetWifiSocketServer & FreeRTOS projects in workspace).
        dc42 administrators @sigxcpu
        @sigxcpu said in New firmware 2.0RC5 available:
        The IDE should need no additional configuration for the RTOS build, except that you need to configure build variable GccPath in the FreeRTOS project just as in the other projects.
          dc42 administrators @BMMal
          @bmmal said in New firmware 2.0RC5 available:
          I had canceled a print and then started another using the "Upload and Print" button. As the machine started the print, the controller reset. I can repeat this reliably. This does not appear to be an issue if I manually select a file to print though.
          Here are the diagnostics after:
          The diagnostics show that the most recent reset was a user-commanded software reset. So unfortunately I can't tell the reason for the reset. But I will test the Upload & Print function.
            Thanks for your report. Sadly I can't tell anything from those diagnostics, they look normal.
            BMMalundefined 1 Reply Last reply Reply Quote 0
              I have found a bug in RC5 that could explain some instances of not being able to maintain a reliable network connection. If the firmware times out trying to get information for a file (which is most likely when there are large GCode files and the SD card has a small cluster size), it doesn't close the file. This could result in the firmware running out of file handles. It also explains the report by a user who was unable to delete a GCode file until he restarted the Duet.
              I will release RC6 to fix this, probably tomorrow.
              • BMMalundefined
                BMMal @dc42
                Just had an instance where a print finished, I manually uploaded another, then selected it for printing and the controller reset.
                I just replaced my mechanical relay, that I previously suspected of putting my controller in a slow state, with an SSR. Strangely, the end.g file did not turn this relay off as it should have when the previous print finished... M42 P7 S0 ; Turn off Vacuum
                Duet Ethernet - Most likely the most recent Edge firmware
                Duet X5
                7" Panel Due V2
                Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                  If you haven't restarted the Duet since the reset, please run M122 and post the results here.
                  • BMMalundefined
                    BMMal @dc42
                    the end.g did turn off the vacuum relay properly. Sorry, I forgot that I had turned it back on manually.
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet Ethernet 1.02 or later + DueX5
                    Board ID: 08DDM-9FAM2-LW4SD-6JTDL-3S86R-KJW3X
                    Used output buffers: 3 of 20 (16 max)
                    Static ram: 28452
                    Dynamic ram: 96544 of which 0 recycled
                    Exception stack ram used: 420
                    Never used ram: 5656
                    Task NETWORK ready, free stack 332
                    Task HEAT blocked, free stack 1200
                    Task MAIN running, free stack 3556
                    Last reset 00:19:27 ago, cause: software
                    Last software reset at 2018-05-25 15:36, reason: Hard fault, spinning module GCodes, available RAM 5480 bytes (slot 3)
                    Software reset code 0x4033 HFSR 0x40000000, CFSR 0x00000400, ICSR 0x04417803, BFAR 0xe000ed38, SP 0x20004994
                    Stack: 004307cf 004307d0 01000000 00000002 00000000 00000001 00000001 00000007 0042abab 00430a26 81000000 00000000 20004cdc 20004a78 a5a5a5a5 a5a5a5a5 0044c3ab 200001e0 00000000 0000000a 2000b170 2001e828 004322c9 00000000
                    Error status: 0
                    Free file entries: 8
                    SD card longest block write time: 2.2ms
                    MCU temperature: min 25.2, current 27.0, max 27.2
                    Supply voltage: min 24.0, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0
                    Driver 0: ok, SG min/max 0/1023
                    Driver 1: ok, SG min/max 0/1023
                    Driver 2: standstill, SG min/max 0/1023
                    Driver 3: ok, SG min/max 0/1023
                    Driver 5: standstill, SG min/max 0/103
                    Driver 6: standstill, SG min/max not available
                    Driver 7: standstill, SG min/max not available
                    Driver 8: standstill, SG min/max not available
                    Driver 9: standstill, SG min/max not available
                    Expansion motor(s) stall indication: yes
                    Date/time: 2018-05-25 15:56:29
                    Slowest main loop (seconds): 0.085543; fastest: 0.000076
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 156, MinFreeDm 150, MaxWait: 4292056348ms, Underruns: 0, 0
                    Scheduled moves: 6445, completed moves: 6415
                    Bed compensation in use: none
                    Heater 0 is on, I-accum = 0.0
                    Heater 1 is on, I-accum = 0.2
                    Segments left: 0
                    Stack records: 4 allocated, 0 in use
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is doing "G1 X224.503 Y63.367 E0.069" in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    HTTP sessions: 1 of 8
                    Interface state: 5
                    === Filament sensors ===
                    Extruder 0 sensor: ok
                    Extruder 2 sensor: ok
                    === Expansion ===
                    DueX I2C errors 0
                    Duet X5
                    7" Panel Due V2
                    • Knaudlerundefined
                      Knaudler
                      hello
                      DWC 1.21.1
                      showing only 1 Fan slider ?
                      and that responds slower
                      on older Webgui 1.21 there are sliders for all pwm fans - works better
                      • Synlorundefined
                        Synlor
                        I had a print fail again, but this time it wasn't through Octoprint; I ran it straight off the SD card in DWC. It just said disconnected, and when I connected back again the Duet had reset itself.
                        Here is the M122:
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet WiFi 1.0 or 1.01 + DueX5
                        Board ID: 08DAM-999TL-MQ4S8-6J9D8-3SJ6N-15B3W
                        Used output buffers: 1 of 20 (9 max)
                        Static ram: 28452
                        Dynamic ram: 96600 of which 16 recycled
                        Exception stack ram used: 348
                        Task NETWORK ready, free stack 440
                        Task DHTSENSOR blocked, free stack 36
                        Task HEAT blocked, free stack 1256
                        Task MAIN running, free stack 3588
                        Last reset 00:00:18 ago, cause: software
                        Last software reset at 2018-05-25 20:34, reason: Assertion failed, spinning module Platform, available RAM 5284 bytes (slot 3)
                        Software reset code 0x4090 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f80e, BFAR 0xe000ed38, SP 0x2001ffb4
                        Stack: 2001e6a0 2001e6d4 00445509 00000000 00000001 00000001 20006c68 20006bf4 00444885 2001e6ec 20006bf4 00000000 00f00000 e000ef34 c0000018 00000003 004449c7 00444738 61000000 b082b430 b33b9d04 b2c96804 41b4f041 3480f444
                        Error status: 0
                        Free file entries: 10
                        SD card 0 detected, interface speed: 12.0MBytes/sec
                        MCU temperature: min 50.2, current 50.6, max 50.7
                        Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0
                        Driver 5: standstill, SG min/max not available
                        Date/time: 2018-05-25 20:35:16
                        Slowest main loop (seconds): 0.005176; fastest: 0.000070
                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                        Scheduled moves: 0, completed moves: 0
                        Heater 3 is on, I-accum = 0.0
                        Segments left: 0
                        file is idle in state(s) 0
                        === Network ===
                        - WiFi -
                        Network state is running
                        WiFi firmware version 1.21
                        WiFi MAC address 5c:cf:7f:2c:27:2d
                        WiFi Vcc 3.38, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 13136
                        WiFi IP address 192.168.2.143
                        WiFi signal strength -58dBm, reconnections 0, sleep mode modem
                        === Expansion ===
                        DueX I2C errors 0
                        This was a different GCode file then the one that failed previously in Octoprint. Funny enough it was about 3.5 hours into the print again.
                          @synlor, thanks for your reports. The task that manages the DHT sensor ran out of stack in both cases. I will increase the stack size for that task in the next build.
                            @bmmal, thanks for your report. It looks like it was reconfiguring a filament monitor at the time of the crash. Do you have any M591 commands in your start or end GCode, or anywhere else other than in config.g? What type(s) of filament monitor do you have? Are you using the 2.0RC5 binary downloaded from the Releases area of my github repo?
                            • zerspaner_gerdundefined
                              zerspaner_gerd
                              It seems the filament management is broken.
                              "filaments.csv" file is no longer updated automatically.
                              If I change this hand, I can not load filament via DWC anymore.
                              With M701 S"TEST" , an error occurs shortly before completion.
                              Can anybody confirm this!
                              Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                              MSquaredundefined zerspaner_gerdundefined 2 Replies Last reply Reply Quote 0
                              • MSquaredundefined
                                MSquared @zerspaner_gerd
                                @zerspaner_gerd I also cannot seem to load filaments anymore.
                                  zerspaner_gerd @zerspaner_gerd
                                  @zerspaner_gerd said in New firmware 2.0RC5 available:
                                  The error with M701 S "test" is due to the M502!
                                  @dc42 Is this intended the M502, all tools and heaters off?
                                  • DocTruckerundefined
                                    DocTrucker
                                    Running 1.21.1RC5 and Christian Hammacher's 1.21.1.
                                    I can see the simulation time appended to the end of the file, but not visible on DWC?
                                    • BMMalundefined
                                      BMMal @dc42
                                      @dc42 Yes, I'm using your RC5 binary
                                      I do have simple switch filament monitors. The machine disables/deconfigures the filament monitors at the start of each print to make sure there are not any from a previous print, see start.g.
                                      Then using KISSlicer's matl gcode tab, it automatically sets them back up appropriately as a tool is selected:
                                      *G10 P<EXT> S<TEMP> R<TEMP> ; S Active Temp, R standby temp
                                      M572 D<EXT> S0.045
                                      ; Retract Settings S Length, R Extra L
                                      ; F Feedrate, T Unretract Rate, Z Z-hop
                                      M207 S4 R0 F900 T900 Z0
                                      M98 P/macros/<EXT>_Config_T<EXT>_Trigger*
                                      This is my Start.g:
                                      *M84 ;Turn Motors off so tool change scripts are not exectued when initializing temps
                                      M140 S85
                                      G10 P0 S0 R0
                                      T0
                                      M207 S0 R0 F1980 T1980 Z0
                                      G10 P1 S0 R0
                                      T1
                                      G10 P2 S0 R0
                                      T2
                                      G10 P3 S0 R0
                                      T3
                                      T-1
                                      ;Disable the filament out triggers
                                      M591 D0 P0
                                      M591 D1 P0
                                      M591 D2 P0
                                      M591 D3 P0
                                      ;Reset the Flowrate Multipliers to 100% for all drives
                                      M221 D0 S100
                                      M221 D1 S100
                                      M221 D2 S100
                                      M221 D3 S100
                                      M220 S100 ;Reset Speed Multiplier to 100%
                                      M98 P/macros/High_Quality_Mode ; Set quality mode
                                      M42 P7 S255 ; Turn on Vacuum Pump*
                                      Duet X5
                                      7" Panel Due V2
                                        Thanks. I found a possible problem with configuring/deconfiguring filament monitors while a print is active. I believe I have fixed it. However, I advise against deleting filament monitors (or changing their type in other ways) once they have been configured. Instead, I suggest you use the M591 S parameter to enable or disable the filament monitor.
                                        Can you explain what problems you were getting before, i.e. what you mean by "to make sure there are not any from a previous print" ?
                                          dc42 administrators @DocTrucker
                                          @doctrucker said in New firmware 2.0RC5 available:
                                          That's correct, DWC doesn't support it yet (neither does PanelDue).
                                          DocTruckerundefined 1 Reply Last reply Reply Quote 0
                                            dc42 administrators @zerspaner_gerd
                                            M502 used to just reset those configuration parameters that are overridden in config-override.g (if you have it). Following complaints that this doesn't match the behaviour of other firmwares, it now resets the machine by running config.g but not config-override.g. Therefore it redefines the tools - which means deleting the original definitions. That's why all the tool heaters are turned off.
                                            Where are you running M502, and why?
                                            zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
