    Can I add external extruder motor to expansion pins in Duet 0.6?
    • allankisaiswaroopundefined
      allankisaiswaroop
      Hi ,
      I want to connect external Extruder motor to expansion pins in Duet 0.6? Is it possible and I want what tweak i use to do in config.g?
        Yes, the Duet 06 supports 4 additional drivers connected to the expansion connector. Two expansion boards were created to provide the extra drivers: the DueX4 (providing 4 more motors and heaters) and the Duet Shield (providing 2 more extruders and heaters). It is still possible to buy the Duet Shield from reprapltd.com. Or you can connect your own drivers to the expansion bus.
