    Homing issue when transfering to Duet Wifi from 0.8.5
    • JonnyBrylcreem
      JonnyBrylcreem last edited by
      I'm in the process of swapping from a 0.8.5 board to Duet WiFi on my Ormerod 2.
      As far as I can tell it should be a straight swap between the two boards and I've got everything working apart from I can't get the machine to home properly now.
      The Y axis is fine as that's just a microswitch but I am having trouble with the X axis. It is using the standard Z probe that came with the machine and using that to home the x axis as well as the Z.
      I see changes in the Z probe value when it gets close to an object so as far as I can tell it is working correctly but it doesn't want to trigger. When trying to home the X axis the head just wants to keep going and runs into the Z upright.
      I'm using the standard files as supplied on the SD card and have swapped values that I was using on the 0.8.5 card (except I've probably missed something). Firmware version is 0.19 attached are my config and homeall files:
      0_1527700605518_config.g
      0_1527700626668_homeall.g
        See the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/v2-dev/WHATS_NEW.md
        for all the firmware versions you skipped. In particular this bit in the upgrade notes for version 1.20:
        If you are using a Duet to control a RepRapPro Ormerod, Huxley Duo or Mendel 3 printer or any other printer that uses the Z probe to do X homing, you need to add line M574 X1 S2 to config.g.
        • JonnyBrylcreem
          My bad, thanks a million
          • JonnyBrylcreem
            After updating Firmware to 1.21 and tweaking a few settings it now works fine. Thanks again
