    New edge firmware 1.17dev8 (replaces 1.17dev7)
    Firmware wishlist
    3615
      I have just released firmware 1.17dev7 on GitHub. From the WHATS_NEW file:
      • Implemented G29 S1 (load bed height map from file)
      • Long moves are now segmented when grid compensation is in use so as to follow the contours of the bed
      • Default max temperature excursion increased to 15C
      • M571 now accepts a P parameter to select the output pin (edit: M571 isn't working correctly in this release)
      • Removed Duet WiFi prototype 1 build configuration and added RADDS build configuration
      • M104 and M109 default to tool 0 if no tool selected and no T parameter provided
      • M109 now selects the tool after setting the active temperature if it was not already selected
      • M558 now uses the R parameter to set the Z probe recovery time
      • Fixed an issue in earlier 1.17dev builds when macros were run concurrently with printing
      This release completes all the planned new features for the 1.17 release, but I may implement some minor bug fixes before the official release.
      • auser
        auser last edited by
        Please excuse my ignorance: does this impact the duetwifi beta boards?
          No, prototype 1 was for internal testing and only 2 boards were ever made.
            I just found a bug in 1.17dev7: after you have printed a file from SD card, you need to reset the printer before you can do any further movement. Will be fixed soon.
            • heathmanc
              heathmanc last edited by
              Maybe I don't know how to use this new feature, but I homed my printer, did an autocalibrate and put the settings in the config file, did a G29 and then reset the controller. I put the G29 S1 into my startup script, but when I went to print, everything was WAY skewed, like not even resembling the part.. So, at this point, I rehomed, autocalibrated, ran a G29, and the print the file without the G29 in the beginning of it, same result. What am I doing wrong? Grid is defined with M557 R70 S20.
              Charles
                Can you post the heightmap.csv file generated by a G29 that giving you bad results?
                • heathmanc
                  RepRapFirmware height map file v1 generated at 2016-11-08 16:06
                  xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
                  -60.00,60.10,-60.00,60.10,70.00,20.00,7,7
                  0,0,0.119,0.070,0.194,0,0
                  0,0.012,0.088,-0.040,0.056,0.037,0
                  0.044,-0.005,-0.044,0.182,0.068,0.008,0.013
                  0.037,-0.010,-0.007,0.140,0.025,-0.023,-0.007
                  -0.018,-0.088,-0.057,0.138,0.036,-0.082,-0.181
                  0,0.050,-0.087,-0.075,-0.006,-0.038,0
                  0,0,-0.024,0.025,-0.049,0,0
                    I can't see anything wrong with your height map, although you have a couple of fairly large errors at y=-60 and X= +/- 20mm. What sort of skew are you getting?
                    • heathmanc
                      I haven't let it print more than a couple of perimeters, it's pretty wild and I can't even make out what the part is.
                        Is it just the Z height that is behaving wildly, or X and Y as well?
                          OK, I think I found a problem that could explain what you are seeing. I suggest you roll back to dev6 until I have dev8 ready.
                          • heathmanc
                            Ok, done! Glad I'm not completely crazy. The x and y are really skewed, z axis does some crazy things as well, especially when pausing the print.
                              I have just released 1.17dev8, which fixes the issues I introduced in 1.17. I don't anticipate making any more major changes before 1.17 release, just fixes for any new bugs.
                              • Adamfilip
                                Adamfilip last edited by
                                Cant seem to get it working
                                Updated. restarted several times
                                "No valid grid defined for G29 bed probing" is error
                                this is in my config.g
                                M557 X20:260 Y0:240 S10 ; define a grid covering the XY area indicated with the specified grid spacing
                                Sending G29 to activate
                                • Adamfilip
                                  hmm when i increased Spacing from S10 to S20 it started working.
                                    With your original M557 command, you should get an error message saying that there are too many probe points - except if the M557 command is in config.g then you won't see the message.
                                    • Adamfilip
                                      Ok.. What is the max limit of points?
                                      • Firebug24k
                                        Firebug24k last edited by
                                        DC42, on my delta I don't use any XY offset for your IR probe when running G30 autocalibration and it works fine. When I run G29 grid levelling after, should I have entered an XY offset via G31 first or not? My probe is offset about -40mm in the Y direction.
                                        • Adamfilip
                                          Grid leveling is working incredibly well. Never had such a good first layer over my entire bed.
                                          Thank you DC42
                                            I'm glad it's working well for you!
                                            The maximum number of points is currently 121 on the wired Duet and 441 on the Duet WiFi. However, the underlying grid is rectangular so when using a circular probing area the actual max number of points is about pi/4 times these values.
                                            You should configure the probe offset. During auto calibration the probe offset is ignored.
                                            • 32034
                                              32034 last edited by
                                              @dc42:
                                              You mean that G29 should have the same X Y Z offsets as G31 in config.g?
                                              If Z probe section in config.g looks like this,
                                              [c]; Z probe section
                                              M558 P1 X0 Y0 Z1 H3 F100 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 100mm/min, travel speed 5000mm/min
                                              G31 P500 X-60.0 Y0.0 Z1.30 ;Set the probe height and threshold
                                              [/c]
                                              then bed.g should look like this for Auto bed compensation?
                                              [c]; bed.g
                                              ; M561 ; clear any bed transform, otherwise homing may be at the wrong height
                                              G28 ; home the printer
                                              M557 X10:275 Y15:190 S25 ; define a grid covering the XY area indicated with 25mm grid spacing
                                              G29 X-60.0 Y0 Z1.30 ;probe levelling grid with prob offsets from config.g
                                              [/c]
                                              Edited. Removed .1 from G29
                                                No, I mean set up the XYZ offsets in your G31 command, and G29 will use them.
                                                • Adamfilip
                                                  is there a way to fade the grid correction after a certain amount of layers. I noticed that its still adjusting Z height even after 50mm of print height.
                                                  • jnofsinger
                                                    jnofsinger last edited by
                                                    I am trying to run the new grid correction and running into an issue. I have this in my config.g
                                                    G31 X0 Y0 Z19.4 P500
                                                    and the bed file
                                                    G30 P0 X0 Y0 Z-99999
                                                    ; Probe the bed and do 6- or 7-factor auto calibration
                                                    G30 P0 X-73.6 Y-42.5 Z-99999 ; X tower
                                                    G30 P1 X0 Y-85 Z-99999 ; between X and Y towers
                                                    G30 P2 X73.6 Y-42.5 Z-99999 ; Y tower
                                                    G30 P3 X73.6 Y20 Z-99999 ; between Y and Z towers
                                                    G30 P4 X0 Y67 Z-99999 ; Z tower
                                                    G30 P5 X-73.6 Y20 Z-99999 ; between Z and X towers
                                                    G30 P6 X-36.8 Y-21.25 Z-99999 ; half way to X tower
                                                    G30 P7 X36.8 Y-21.25 Z-99999 ; half way to Y tower
                                                    G30 P8 X0 Y42.5 Z-99999 ; half way to Z tower
                                                    G30 P9 X0 Y0 Z-99999 ; centre, and auto-calibrate 6 factors
                                                    G30 P10 X0.00 Y40.00 Z-99999 ; Z tower
                                                    G30 P11 X-34.64 Y20.00 Z-99999 ; between Z-X towers
                                                    G30 P12 X0 Y0 Z-99999 S6
                                                    M557 R90 S20
                                                    G29
                                                    The auto calibration works fine for my delta. When it runs the G29 command the zprobe doesn't report/trigger properly (it is 19.4mm) above my bed. It pushes my probe out of the way down and gives the message
                                                    "Zprobe triggered before probing move started" (if the printer is not homed to top)
                                                    OR
                                                    "Zprobe was not triggered before probing move" (if the printer is homed before running)
                                                    I assume the G31 isn't being read for G29? what option do I need to set for the probe to trigger correctly? Sorry if this has been answered for a delta, haven't found it in the threads.
                                                    Thanks,
                                                    Jim
                                                      I think that your very large Z probe trigger height has exposed a bug in the G29 probing, which I will fix in today's release.
