    New edge firmware 1.17dev8 (replaces 1.17dev7)
    Firmware wishlist
    5.0k
    • 32034undefined
      32034
      @dc42:
      I'm glad it's working well for you!
      The maximum number of points is currently 121 on the wired Duet and 441 on the Duet WiFi. However, the underlying grid is rectangular so when using a circular probing area the actual max number of points is about pi/4 times these values.
      You should configure the probe offset. During auto calibration the probe offset is ignored.
      You mean that G29 should have the same X Y Z offsets as G31 in config.g?
      If Z probe section in config.g looks like this,
      [c]; Z probe section
      M558 P1 X0 Y0 Z1 H3 F100 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 100mm/min, travel speed 5000mm/min
      G31 P500 X-60.0 Y0.0 Z1.30 ;Set the probe height and threshold
      [/c]
      then bed.g should look like this for Auto bed compensation?
      [c]; bed.g
      ; M561 ; clear any bed transform, otherwise homing may be at the wrong height
      G28 ; home the printer
      M557 X10:275 Y15:190 S25 ; define a grid covering the XY area indicated with 25mm grid spacing
      G29 X-60.0 Y0 Z1.30 ;probe levelling grid with prob offsets from config.g
      [/c]
      Edited. Removed .1 from G29
        No, I mean set up the XYZ offsets in your G31 command, and G29 will use them.
        • Adamfilipundefined
          Adamfilip
          is there a way to fade the grid correction after a certain amount of layers. I noticed that its still adjusting Z height even after 50mm of print height.
          • jnofsingerundefined
            jnofsinger
            I am trying to run the new grid correction and running into an issue. I have this in my config.g
            G31 X0 Y0 Z19.4 P500
            and the bed file
            G30 P0 X0 Y0 Z-99999
            ; Probe the bed and do 6- or 7-factor auto calibration
            G30 P0 X-73.6 Y-42.5 Z-99999 ; X tower
            G30 P1 X0 Y-85 Z-99999 ; between X and Y towers
            G30 P2 X73.6 Y-42.5 Z-99999 ; Y tower
            G30 P3 X73.6 Y20 Z-99999 ; between Y and Z towers
            G30 P4 X0 Y67 Z-99999 ; Z tower
            G30 P5 X-73.6 Y20 Z-99999 ; between Z and X towers
            G30 P6 X-36.8 Y-21.25 Z-99999 ; half way to X tower
            G30 P7 X36.8 Y-21.25 Z-99999 ; half way to Y tower
            G30 P8 X0 Y42.5 Z-99999 ; half way to Z tower
            G30 P9 X0 Y0 Z-99999 ; centre, and auto-calibrate 6 factors
            G30 P10 X0.00 Y40.00 Z-99999 ; Z tower
            G30 P11 X-34.64 Y20.00 Z-99999 ; between Z-X towers
            G30 P12 X0 Y0 Z-99999 S6
            M557 R90 S20
            G29
            The auto calibration works fine for my delta. When it runs the G29 command the zprobe doesn't report/trigger properly (it is 19.4mm) above my bed. It pushes my probe out of the way down and gives the message
            "Zprobe triggered before probing move started" (if the printer is not homed to top)
            OR
            "Zprobe was not triggered before probing move" (if the printer is homed before running)
            I assume the G31 isn't being read for G29? what option do I need to set for the probe to trigger correctly? Sorry if this has been answered for a delta, haven't found it in the threads.
            Thanks,
            Jim
              I think that your very large Z probe trigger height has exposed a bug in the G29 probing, which I will fix in today's release.
                @Adamfilip:
                That will be supported in today's release.
                  @dc42:
                  PS - sending M558 H25 prior to G29 should work around the problem.
                    jnofsinger
                    Just a quick note, the bug noted for my high Z probe is fixed in RC1 without adding H558. Thanks for the quick response and awesome firmware!
