    Ultimaker Z axis config problem.
    • Afigentusundefined
      Afigentus
      Hi. I tried configure my Ultimaker. Z axis on home action move to the endstop and set position ftom config. But ufter any G command for X,Y or Z axis bed moving to zero position and on the next G command to max position and so on the circle. During print simulation or real print beg any time go up and down.
      ; generated by RepRapFirmware Configuration Tool on Sat Jun 02 2018 22:48:38 GMT+0300 (RTZ 2 (зима))
      ;M111 S0 ; Debug off
      M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M667 S0 ; Select Cartesian
      G21 ;Set in mm
      M569 P0 S1 ; Drive 0 goes backwards
      M569 P2 S1 ; Drive 2 goes backwards
      M92 X80 Y80 Z400 E377 ; Set steps per mm
      M203 X18000 Y18000 Z2400 E2700 ; Set maximum speeds (mm/min)
      M201 X2500 Y2500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I20 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z294 S1 ; Set axis minima
      M208 X213 Y199 Z0 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low endstops
      M574 Z2 S1 ; Set active high endstops
      M558 P5 X0 Y0 Z0 H5 F120 T6000 I1 ; Set Z probe type to switch and the dive height + speeds
      G31 P600 X0 Y0 Z0.4 ; Set Z probe trigger value, offset and trigger height
      M557 X15:198 Y15:185 S20 ; Define mesh grid
      M305 P0 X201 ; Configure thermocouple for heater 0
      M301 H1 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P1 X200 ; Configure thermocouple for heater 1
      M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S0.1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      T0 ; Select first tool
      ;M501 ; Run config-override.g
      M550 PDuetUltimaker ; Set machine name
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M552 S1 ; Enable network
      • BPisLifeundefined
        BPisLife
        @afigentus said in Ultimaker Z axis config problem.:
        M574
        Can you post the Homez.g file?
          Afigentus
          ; homez.g
          ; called to home the Z axis
          G91 ; relative positioning
          G1 S1 Z295 F6000 ; move Z up until the switch triggers
          G1 Z-10 F6000 S2 ; lift Z relative to current position
          G1 S1 Z295 F500 ; move Z up until the switch triggers
          G92 Z0.2 ; set Z position to trigger height
          ;G91 ; relative positioning
          ;G1 Z5 F100 S2 ; lift Z relative to current position
          G90 ; absolute positioning
          HomeZ action is correct, but then ...
            dc42 administrators @Afigentus
            1. You are moving Z up to a Z max endstop switch, but then telling the firmware that the nozzle-to-bed distance is 0.2mm at that point. That isn't right.
            2. In your M208 commands you have said that the Z minimum is 294mm and the Z maximum is zero. That isn't right either, the minimum can't be greater than the maximum.
            The Z coordinate refers in all cases to the distance between the nozzle and the bed. So if it is the bed that moves up and down, the Z max position is when the bed is at its lowest point, and the Z min position is when the bed is at its highest point.
            So I suggest you fix your M208 commands, and re-evaluate whether you are homing to a maximum or minimum Z endstop.
            HTH David
              Afigentus
              many thanks. figured out with your help. works as it should.
