Hotend temp control from paneldue
  • I have a due ethernet and panel due. I can change the value of the active temp for the hotend on the panel and the values are passed to the dwc, but it does not heat up when selected on the panel, I can activated it from the dwc.
    The heatbed can be controlled from the panel and dwc as expected.
    Is this by design?
    Thanks
    If the tool is not active when you set the temperature, touch the nozzle icon at the top of the temperatures column to select it.
  • You can put a T0 at then end of config.g, to avoid this, and other "no tool selected" behaviors.
    You may or may not want this... for example, if you have multi extruders... anyway, it is one option.
