RTOS 2 and Fan control.
  • I have upgraded to the latest software versions and am having problems with the cooling fans.
    I can see the fan sliders in the DWC after editing the config file as shown below.
    The problem is that when I move the sliders they just go back to their previous position. After several attempts it will work, it then needs several more attempts to get it to move back again.
    It is the same in Edge, Firefox and chrome. The fans worked fine in the previous software release
    Firmware Version: 2.0(RTOS) (2018-06-05b3)
    WiFi Server Version: 1.21
    Web Interface Version: 1.21.1
    Config extract.
    M106 P0 S0 I0 F500 H-1 ; Print Fan
    M106 P1 S0 I0 F500 H1 T45 ; Hotend fan
    M106 P2 S0 I0 F500 H-1
  • Yup. This has been noted on previous posts. The sliders are more stable on the "print status" tab. On the "machine control", good luck getting the slider to stay in place.
    Thanks for your report, I will fix it in my next release.
Locked
