    DWC not working after update to 2.0 + 1.21.1
    Firmware installation
    • dintidundefined
      dintid
      After firmware upgrade I consistently get some java error when trying to connect to web gui. (see image)
      My machine were functioning fine and decided to update firmware to newest firmware https://github.com/dc42/RepRapFirmware/releases
      I have tried emptying cache. Removed www folder from SD and put in the new again.
      Right now I went as far as doing a reset+erase and uploaded new firmware using SAM-BA and reinstalled the firmware files. I've done it twice as I re-downloaded the firmware files to check for corruption..
      When using M115 on LCD it displays RepRapFirmware for Duet 2 WiFi/Ethernet Firmware_Version: 2.0(RTOS) Electroniscs: Duet
      When using M115 P0 the machine seems to go into some error condition as LED (which is connecte to Duex5) turns off, and some fans turns on..
      I can not connect to it using YAT now even though it is displayed as COM4 in my system.
      Full screen: It's not listing firmware name or version
      RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
        Can you try downgrading DWC to 1.21, to see if that fixes the problem?
