Homing Issues
Well I figured out the M280 command error, it seems like I set my S3D to use P0 instead of P3, so made the change and boom no more M280 error.
I am still getting the homing errors and the M29 error.
maybe those errors are also causing my other errors, so here is my s3d start and stop process.
start gcode from s3d
M280 P3 S160 ; BLTouch alarm release G4 P100 ; delay for BLTouch G28 ; home G29 ; auto bed leveling G1 X0 Y5 Z0.2 F3000 ; get ready to prime G92 E0 ; reset extrusion distance G1 X250 E20 F600 ; prime nozzl
end gcode from s3d
M104 S0 ; turn off extruder M140 S0 ; turn off bed G28 X Y ; home x and y axes M84 ; disable motors
thanks for any help.
The M29 error is probably from having too many points in the grid. Try a higher s value and see if it will let you run it.
Actually it looks like you haven't defined a mesh grid in your config.
should I even have that much in here as the Bed.g file should be called, or is that invoked from S3d?
alright down to 1 error homing error is still happening but auto bed leveling is running as expected.
I invoked the Bed.g file using M32 command.
maybe my issue is in the bed.g file now.
Thanks
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
You may not even need to use bed.g if you're using mesh grid compensation. With beg.g you're limited in points. It ends up being the same as just using a sparce grid.
now it seems like for what ever reason the bed moves down a bit (~.05 to 1mm) after the purge happens....why do my issues keep growing. ehhhhhhhhhh.
Can you post the first 50 or so lines of your sliced gcode file?
figured it out, it was also a strange setting that was in simplify3d. printing well so far, the true test will start tonight.
