    sd card crashed! what to do?
    Firmware installation
    • Tripplekissundefined
      Tripplekiss
      My sd card of my Duet 0.8.5 ethernet is damaged everything is erased. I don't understand now what to do. How i can install my webserver and firmware again in my board. There are guides on the web butt not anymore for the 0.8.5 and the firmware.
      • timcurtis67undefined
        timcurtis67
        Are you sure the card is erased? Did you try putting it into a PC and trying to read it?
        I had a similar indecent but my Duet WiFi wouldn't read the card even though I could see the files with my PC. I ended up replacing the card in the long run and haven't had anymore issues.
          Tripplekiss
          yeah butt, that isn't my problem. I don't know wich firmware i have to choose from and how to set it up. Is it possible that somewhan can send my a image. It doesn't matter which version if my webserver is running iam happy. i got a duet3d 0.8.5 ethernet
          • ayudteeundefined
            ayudtee
            The RepRapFirmware Configuration Tool still works for the Duet 0.8.5:
            https://configurator.reprapfirmware.org/
            Tripplekissundefined 1 Reply Last reply Reply Quote 1
              Tripplekiss @ayudtee
              This post is deleted!
                See https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure for the file structure that you need on the SD card. You can find a link there to the files we ship with the Duet WiFi. The same ones will work on the Duet 085 if you put a compatible firmware version on it. Be aware that with recent firmware versions, some Duet 06/085 users find they need to set a static IP address in config.g, otherwise the Duet keeps rebooting when it tries to start up.
                You will need to use configtool to generate config.g and homing files.
