Z Gap adjusts after purge for no known reason
  • I am having yet another issue....(ehhhhhh)
    After Bed compensation and I purge my nozzle for a bit... my bed moves down about 1mm or so and causes a large gap between the bed and nozzle. The problem is my Z Gap is set and looks good, so I know that this is not my Z0 this has to be some other process running after the purge of the nozzle occurs. The only thing is I am not sure where that Gcode resides.
    here is a video of my issue:
    https://www.youtube.com/watch?v=givpolLc7wE
    and here is a picture of my Z gap at Z0:
    Paper is tight but not to tight against the paper.
    If I were to do this during the print the paper would not even make contact with the nozzle.
    any help would be appreciated
    Thanks
    Please post your bed.g file, and the GCode commands that do the purging if they are in a different file.
    Does the problem still occur if you don't do the purge?
