    cant do auto delta calibration
    • Bustableundefined
      Bustable
      I have recently installed the Duet wifi, smart effector and haydens arms but can not get it to probe correctly.
      I can get it to either crash into the bed or to begin probing in mid air but not to slow down and begin probing correctly.
      i have attached a video to show what is happening
      https://youtu.be/dhw-jiXCt-8
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R157 L400.97 B160 H505 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M558 P5 R0.4 H5(i have set this at various heights between 5 and 100) F100 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
      M557 R157 S20 ; Define mesh grid
        Please follow the commisisoning instructions at https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer?revisionid=HEAD#Section_Commissioning and let us know at which step it fails and what happens.
