auto config woes using smart efector
  • Hi, anycubik linear plus with duet wifi and smart effector and haydns 288mm rods. so I've created some config files using the reprap configurator. It seems to home x and y ok. I've ran the z probe commisioning routine all seems good. I want to do auto calibration to get the bed height but when i run it, it smashes down into the bed everytime arrrgh.
    Here is my config.g file and bed.g file underneath, hopefully somebody can help, let me know if you need another file:
    ; generated by RepRapFirmware Configuration Tool on Mon Jun 18 2018 19:57:02 GMT+0100 (British Summer Time)
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    M665 R136 L288.15 B120 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M550 PMy printer ; Set machine name
    M552 S1 ; Enable network
    M587 S"hidden" P"hidden" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X80 Y80 Z80 E663 ; Set steps per mm
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
    M557 R120 S20 ; Define mesh grid
    M106 P0 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    BED.G:
    ; bed.g
    ; called to perform automatic delta calibration via G32
    ; Probe the bed at 3 peripheral and 0 halfway points, and perform 3-factor auto compensation
    ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
    G30 P0 X0 Y119.9 H0 Z-99999
    G30 P1 X103.84 Y-59.95 H0 Z-99999
    G30 P2 X-103.84 Y-59.95 H0 Z-99999
    G30 P3 X0 Y0 H0 Z-99999 S3
    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
    ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
  • increase the H param on your M558 line (Temporarily) to say H30 and try again sounds like you have your Homed hight set a little high in your M665 line and that is what is causing the initial head crash.
    HTH
    Doug
