    probe offset to make sure that it probes entire heatbed
    • iZippy82
      iZippy82 last edited by
      So happy that i bought my duet wifi, thanks dc42 for the introduction at 3dmeetup.
      My questions is that i'm using a induction sensor which is working great. just changed the design of my hotend and the sensor is now moved about 68 mm on the Y axis.
      My idea is that i want the sensor to probe the entire 300x300 heatbed. which was working fine when the sensor was closer to the hotend. What i've done to make sure it probes the first 68 mm on the Y axis is that I've change the print area
      To this
      M208 X0 Y-68 Z0 S1 ; Set axis minima
      M208 X332 Y313 Z300 S0 ; Set axis maxima
      Z probe
      G31 P500 X0 Y68 Z0.5
      Mesh
      M557 X15:300 Y15:298 S40
      This seems to work, but it doesn't probe all the way at the Y15 when running a G29
      Any tips? or is there a smarter way of doing this?
      Best regards
      Alan
        Thanks for buying the Duet.
        What type of printer do you have? If your printer is a Cartesian or CoreXY, then you've done the right thing. To reach Y=15, the nozzle needs to reach Y=(15-68) so with Ymin=-68 there should be no problem. It's a little different for a delta.
        • iZippy82
          iZippy82 last edited by iZippy82
          Thanks for the reply dc42, it is a Corexy.
          Seems power off and back on again did it, for some reason it was only moving to Y30 before, not Y15
          But it's doing it correct now for some reason.
          Thanks
