    Prusa I3 homeY problem
    • dani3785undefined
      dani3785
      hi,
      i have the proble with my new duet for prusa I3, when i write G28 X the homing is correct, when writing G28 Y homing failed. on DWC X is marked 0 and Y is marked 300... why is?
      this is my config.g
      M569 P0 S0 ; Drive 0 goes back
      M92 X80 Y80 Z3200 E135 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z250 E1000 ; Set accelerations (mm/s^2)
      M906 X800 Y1200 Z800 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0-5 Y-5 Z0 S1 ; Set axis minima
      M208 X215 Y300 Z210 S0 ; Set axis maxima
      M574 X1 Y2 Z1 S1 ; Set active high endstops
      thanks for helping me
      sorry for my bad english
      • nhofundefined
        nhof
        Dani,
        Could you provide more details on what you want the machine to do?
        It sounds like the machine is homing on Y correctly, as you have it set to home Y to the high end (Y=300) with the M574 Y2 command. After homing it is displaying Y=300 in DWC.
        If you want it to come back to Y0 after homing, you should add the movement command for this into the /sys/homey.g and /sys/homeall.g files.
        May need to look something like this:
        G1 Y310 F4000 S1 ; this will move Y to the end stop home position
        G1 Y0 F4000 ; after homing, this will move Y to 0 position
        Please tell us if this is what you want. If you are seeing other errors please also post your homey.g and homeall.g files.
        • dani3785undefined
          dani3785
          when i send G28 Y the bed move to Y endstop but after homing the bed dont move to Y+, move only yet to Y-, to Y endstop.
          On DWC, after home Y, Y head positio is 300.
          this is my homeY.g
          G91 ; relative positioning
          G1 S1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F600 ; go back a few mm
          G1 S1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
          G90 ; absolute positioning
          thanks
            This command in config,g:
            says that the Y endstop is at the Y-max end of the axis (Y2). But these commands in homey.g:
            are trying to home to minimum Y.
            • nhofundefined
              nhof
              @dani3785
              To build on what David said: You say the machine is homing properly, but will not move in the positive direction, this indicates that the M574 command is incorrect, as it is telling the printer that it is at Y=300 when homed, rather than Y-0. Then when you try to move in +Y direction it will block the motion due to axis travel limits.
              Most likely you can fix the error by changing from:
              to:
              M574 X1 Y1 Z1 S1 ; Set active high endstops
              This will tell the system that it is at Y0 when it hits the Y home sensor.
              • dani3785undefined
                dani3785
                thank you @dc42 and @nhof, problem solved.
                i have changed from
                ...M574 X1 Y2 Z1 S1 ; Set active high endstops
                to
                ...M574 X1 Y1 Z1 S1 ; Set active high endstops
                i'm really happy
