Extruder drive spinning really fast
  • Hi,
    I've progressed further along my change to duetwifi and smart effector on my anycubic linear plus.
    Now everything is up and running but when the printer is just about to print the gcode file, the extruder drive spins at what looks like at least 10 times the speed it should be, probably more. Any idea why this would be? I have it wired into the correct driver port?
    I'm using Cura 2.4.0 to slice
    I've inluded my config.g below, if you need a different one please let me know. many thanks
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    M665 R136 L288.15 B120 H217 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M550 PMy printer ; Set machine name
    M552 S1 ; Enable network
    M587 S"xxxxxxxxxxx" P"xxxxxxxxx" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X80 Y80 Z80 E663 ; Set steps per mm
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z-0.211 ; Set Z probe trigger value, offset and trigger height
    M557 R120 S20 ; Define mesh grid
    M106 P0 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    M501
