    Defining G29 Grid plane
    • Puppet172
      Puppet172 last edited by
      I have the Grid defined with M557 in config but it still doesnt allow me to run the mesh bed leveling. Is there anything else i need to do?
      0_1529804473162_config (1).g
        If you try sending that M557 command from the GCode Console, you will find that it has too many grid points, and you will get a suggestion for the value you should increase the spacing to.
        • Puppet172
          Puppet172 last edited by Puppet172
          What is the max amount of Grid points allowed? Is there a way to make more of them?
          Also when i try to change the trigger height for my z probe it doesnt really seem to be changing it. Why would this be occuring?
            dc42 administrators @Puppet172 last edited by
            @puppet172 said in Defining G29 Grid plane:
            the maximum us 441 e.g. 21 x 21.
            Possibilities include;
            1. You have a config-override.g. file on your system containing a G31 command that is overriding the one in config.g;
            2. You haven't put the G31 line after the M558 command in config.g.
            • Puppet172
              The G31 command it after the M558 command. So are there any other possibilities of why it wouldn't be changing?
              Also i don't have a override file so that can't be it
