    Bayonet Cable Terminal for the Duet3d Delta Smart Effector
    • heapstarundefined
      heapstar
      I have designed a Bayonet Cable Terminal for the Duet3d Delta Smart Effector. It is made for igus CF9.02.18 Chainflex cable and has an anti backlash Bowden clip also. Its itentional idea was to change effector without using tools and prevent wires from moving. First runs looks promising fine. You may use it with other cables with about 9.5mm diameter or just thicken it up with a printed shell thing or use tape to thicken it up. Or just change the parametric design in Onshape to your needs.
      click pic for footage
      STL on Gitlab
      Onshape CAD files
      Gruß
      Niko
      • Chipsa82undefined
        Chipsa82
        Nice! is this just to route the cable or does it also include some sort of quick connect connector to disconnect the whole effector?
        • heapstarundefined
          heapstar
          It is just to route the cable, having a handle for M16 nut and anti backlash clip.
          Gruß
          Niko
