    Heater fault trouble
    • Ricky_Grade10undefined
      Ricky_Grade10
      Alright boys, I'm getting a heater fault shortly after starting a print. I can autotune it fine and bring it up to temp, no big deal. But when I run a print, I get a fault after it starts. Is there one of those light things on the board to tell me when the hotend is working like the heat bed?
        Yes, there are LEDs on the board for each heater output.
        After running auto tuning, you need to save the parameters in one of two ways:
        • If you are not using config-override.g, then run M307 H1 to find the resulting parameters, and edit them into a M307 h1 command in config.g;
        • If you are using config-override.g, send M500 to save the heater parameters in config-override.g.
        See also https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them.
