    Start/Stop print Stall detected on driver(s)
    1.1k
    • macpitundefined
      macpit
      I build a new Delta and all works, with sensorless homing, Auto Delta Calibration and mesh.
      G28 and G32 works fine from the Web GUI, manual started.
      But within Simplify 3D i have at the start of the print Stall detected on driver(s) printer paused, then i can resume and start the print.
      After the print with the end Script i have the same issue Stall detected on driver(s) and the printer paused.
      My start Script in Simplify:
      G28		; Home
      G32		; Home and calibrate
      G1 Z5	        ; Lift Z 5mm
      M300 S500 P1000	; Play Beep
      M572 D0 S0.25	; Set Linear
      My end Script in Simplify:
      M106 P0 S0  ; Turn off Fan 0
      M104 S0     ; Turn off Extruder
      M140 S0     ; Turn off Bed
      G28 	    ; Home XYZ,
      M84 	    ; Disable motors
      Simplify produced G-Code:
      G90
      M83
      M106 S255
      G4 P500
      M106 S0
      M140 S70
      M190 S70
      M104 S220 T0
      M109 S220 T0
      G28		; Home
      G1 Z5
      M572 D0 S0.25	; Set Linear Advance
      G1 E-4.0000 F3600
      G1 Z0.150 F1200
      ; process Process1
      ; layer 1, Z = 0.150
      T0
      ; tool H0.150 W0.450
      ; skirt
      G1 X26.575 Y-19.455 F9000
      G1 E4.0000 F1080
      G1 X26.575 Y19.455 E1.0920 F2400
      G1 X26.335 Y20.034 E0.0176
      Home Delta:
      M915 X Y Z S2 R2 F0	    		; set stall detect drives, S-threshold (-64 to 63), F1 filtered, R-log only
      M400					; make sure everything has stopped before we make changes
      M913 X50 Y50 Z50			; reduce motor current to 50% to prevent belts slipping
      G91					; use relative positioning
      G1 S1 X700 Y700 Z700 F3000		; move all carriages up 700mm, stopping at the endstops
      G1 Z-35 F2000				; down a few mm so that we can centre the head
      G90					; back to absolute positioning
      M400					; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100 Z100			; motor currents back to normal
      G1 X0 Y0 F2000				; centre the head and set a reasonable feed rate
      M915 X Y Z S1 R0 F0			; Disable stall for prevent false detect
      Config:
      ; generated by RepRapFirmware Configuration Tool on Fri Jun 22 2018 21:51:49 GMT+0200 (CEST)
      G90                             ; Send absolute coordinates...
      M83                             ; ...but relative extruder moves
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R125 L288 B125 H416        ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0                   ; Put your endstop adjustments here, or let auto calibration find them
      M550 PNXT Delta Marc            ; Set machine name
      M552 S1                         ; Enable network
      M587 S"Macao" P"IRIZwlan"       ; Configure access point. You can delete this line once connected
      M586 P0 S1                      ; Enable HTTP
      M586 P1 S0                      ; Disable FTP
      M586 P2 S0                      ; Disable Telnet
      ; Drives / TOFF-> https://forum.duet3d.com/topic/5392/does-m906-set-rms-or-peak-current/38
      M569 P0 S1               ; Drive 0 goes forwards
      M569 P1 S0               ; Drive 1 goes forwards
      M569 P2 S0               ; Drive 2 goes forwards
      M569 P3 S0               ; Drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1         ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 E476.55      ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200    ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E18000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000    ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000 I30; Set motor currents (mA) and motor idle factor in per cent
      M84 S1                          ; Set idle timeout
      M208 Z0 S1                      ; Set minimum Z
      M574 X2 Y2 Z2 S3                ; Set endstops controlled by motor load detection
      M558 P5 R0.4 H5 F1200 T6000     ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1            ; Set Z probe trigger value, offset and trigger height
      M557 R125 S20                   ; Define mesh grid
      ;Bed
      M143 H0 S100                        	  ; Set the maximum bed temperature in c-default is 110c
      M305 P0 T100000 B3950            	  ; Bed thermistor
      M307 H0 A203.7 C745.2 D2.6  B0	          ; Set bed to use PID mode
      ;E3D
      M143 H1 S285                        	  ; Set the max temp of the hot-end in c-default is 280c
      M305 P1 B4725 C7.060000e-8		  ; E3D thermistor
      M307 H1 A324.6 C134.8 D3.7  B0		  ; Set E3D to use PID mode
      M106 P0 S0 I0 F500 H-1          ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45       ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                   ; Define tool 0
      G10 P0 X0 Y0 Z0                 ; Set tool 0 axis offsets
      G10 P0 R0 S0                    ; Set initial tool 0 active and standby temperatures to 0C
      M501				; Load stored parameters sys/config-override.g
      Config override:
      ; Delta parameters
      M665 L288.000 R149.171 H419.739 B125.0 X-0.061 Y0.008 Z0.000
      M666 X-0.112 Y-0.161 Z0.273 A-0.21 B0.45
      ; Heater model parameters
      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
      M307 H1 A490.7 C264.7 D4.1 S1.00 V24.4 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
        I suspect that the stall is occurring in the G28 homing move when the endstop switch is triggered and the motor is stopped abruptly. Try reducing the speed of the initial G1 S1 homing move in homedelta.g.
        • macpitundefined
          macpit
          I don't think is the speed, I change now my home all to:
          M915 X Y Z S2 R2 H400 F0    		; set stall detect drives, S-threshold (-64 to 63), F1 filtered, R-log only
          					; Hnnn (optional) Minimum motor full steps per second for stall detection
          					; to be considered reliable, default 200 (try 400 for 0.9deg motors)
          ;G1 Z-35 F1500				; down a few mm so that we can centre the head
          M915 X Y Z R0				; Disable stall for prevent false detect
          G4 S1
          G1 S0 Z-415 F3000			; down a few mm so that we can centre the head (Test maybe that's stall?)
          My start Script:
          G28
          G32
          Now I start the Print,
          Heating up, then go home stall detected and go to G1 S0 Z-415 F3000.
          After G1 S0 Z-415 F3000 I have stall detection, but why it's detected?
          Bevor that move I have disable stall detection with:
          Regards
          Marc
          • macpitundefined
            macpit
            I think it's a Bug,
            Upload & Print give me stall detection, upload the same as Macro works without stall detection.
            • macpitundefined
              macpit
              That's my small test:
              90
              M83
              M106 S255
              G4 P500
              M106 S0
              M140 S70
              M190 S70
              M104 S220 T0
              M109 S220 T0
              G28
              G32
              G1 E-4.0000 F2400
              G1 Z0.150 F1200
              ; process Process1
              ; END
              G4 S1
              G4 S1
              G4 S1
              G4 S1
              ; layer end
              M98 PStopScript.g
              Upload & Print I have stall detection printer paused,
              Upload as Macro and rund I have no stall detection...
              • macpitundefined
                macpit
                Is there a way to solve this problem?
                  I am on vacation, but if you remind me a few days from now then I'll try to reproduce it.
