    Z axis and homing help
    • Kskiff7034undefined
      Kskiff7034
      Hey guys, I recently finished a D-bot build and I'm having trouble figuring out the z axis. I've got 3 stepper motors: ZA, ZB, and the third on E1, but I'm having trouble getting everything to work properly.
      On the web based configurator, the second section is "Motors". There's two areas -- Axes and Extruders. Do I just add the second extruder and set the motor driver to 2(Z)? Or do I do it another way?
      I'm going to go through this guide again tonight:
      https://duet3d.dozuki.com/Guide/3.)+Configuration+(General+Cartesian)/10
      But if anyone has any other suggestions I'd love to hear them. While I've gotten the X and Y to move as it should, I'm still having issues with homing everything, so any tips would be great, ESPECIALLY for the Z axis.
        Select 2(Z) in the configurator, but in the config.g file that it generates change the M584 line to read:
        M584 X0 Y1 Z2:4 E3
        That tells the firmware to use drivers 2 (aka Z) and 4 (aka E1) for the Z axis.
