Problems with tool selection
Hi all
I use a cartesian style mendelmax 1.5
When I start a print it works fine, the machine homes then it probes the bed next it waits for temps to be reached and it starts printing.
Phenomenal really never had prints turn out this great.However, when a print fails like yesterday and i clean the bed to restart it (print didnt stuck on the bed) it does the same home, probe, but it does not wait for the printhead to reach temp.
Instead the web interface gives me an AJAX error and the printer starts dancing around on the bed.When scouring these forums i found this could have to do with the tool selection, also i found that when you have T0 in your config.g you should start your Gcode for the print with T0 fololowed by M116
I did this but im still having problems with restarting the prints.
Also i updated to the 116 firmware along with the other 2 and did the command for updating it all at once.
Now in the firmware tab on the webinterfac it still states the webcontrol as 1.12 instead of 1.13Could someone give me some advice on this?
Config.g generated with the configurator and as is on my machine right now:
; Configuration file for Duet WiFi (firmware version 1.16)
; generated by RepRapFirmware Configuration Tool on Sun Dec 11 2016 14:52:15 GMT+0100; General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M208 X200 Y200 Z200 S0 ; Set axis maxima; Endstops
M574 Z0 S0 ; Define active low and unused microswitches
M574 X1 Y1 S1 ; Define active high microswitches
M558 P4 X0 Y0 Z1 I1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P600 X25 Y-10 Z1.47 ; Set Z probe trigger value, offset and trigger height; Drives
M92 X80 Y80 Z400 E419.51 ; Set steps per mm
M203 X6000 Y6000 Z300 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y200 Z250 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S260 ; Set maximum heater temperature to 260C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M305 P0 T100000 R4700; Set thermistor + ADC parameters for heater 0
M305 P1 R4700 ; Set thermistor + ADC parameters for heater 1
M307 H1 A449.3 C181.7 D5.9 B0 ; Pid autotune M307 H0 A(gain) C(timeconstant) D(dead time) B0
M307 H0 A49.5 C95.4 D8.9 B0; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 X0 Y0 ; Set tool 0 axis offsets
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 Pmendelmax ; Set machine name
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP; Fans
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
T0
Starting G-code of my slicer plus some of the first movement commands:
; generated by Slic3r 1.2.9 on 2016-12-15 at 19:34:24
; external perimeters extrusion width = 0.40mm
; perimeters extrusion width = 0.67mm
; infill extrusion width = 0.67mm
; solid infill extrusion width = 0.67mm
; top infill extrusion width = 0.67mmM190 S90 ; set bed temperature
M104 S245 ; set temperature
G28
G32
T0
M116
M109 S245 ; wait for temperature to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
G1 E-3.00000 F900.00000
G1 Z2.000 F9000.000
G1 X58.802 Y54.039 F9000.000
G1 Z0.200 F9000.000
G1 E3.00000 F900.00000
G1 X59.283 Y53.564 E0.01446 F2400.000Thank you !!
Your starting gcode looks OK and ought to work. Are you sure that the prints that failed had the T0 and M116 commands in the starting gcode?
I changed the behaviour in version 1.17RC1 to auto-select tool 0 if the slicer issues an M109 command without bothering to select a tool first.
yeah i read that in the other thread.
i was really doubting this part
T0
M116
"Since the M109 S245 came after M116
This Gcode i downloaded this morning from the printer after it failed yesterday evening, there's only one Gcode on it right now.
Maybe its worth to mention i keep the bed on after the failed print so the bed is up to temp when restarting the print.Also a few times i got the error that extrusion was prevented because of cold hotend and after this i changed the starting G-code to what you see here.
could you also elaborate why my firmware is telling me i run the 1.12 version of the web interface while i uploaded the 1.13 version ? should i just try to do the update again ?
Also thanks again !
The M116 should not be necessary in your case because the M109 comes after it. But I have seen cases where the slicer generate the only M104 and M109 commands before the user's custom start gcode. That's why I suggested the M116.
If DWC is reporting that its version is 1.12 and you have already done a page refresh and tried clearing your browser cache, then try uploading 1.13 again. It takes several minutes to install on the Duet WiFi. The blue LED on the wifi module will stop flashing when it has finished installing.
I just updated
WiFi Server Version: 1.03 (ch fork)
Web Interface Version: 1.13Somehow they both didn't get through last time i tried.
Also did an update to the RC1 version, testing it now.
Ok its awesome now!
A big thank you for the help!
