    Smart effector with Duet wifi not triggering on bed leveling
    1.5k
    • Vamporaundefined
      Vampora
      I just installed a smart effector on my tevo little monster. When I go to bed level it just crashes into the plate. The green light does come on when it crashes or when i flick the nozzle.
      here is config.g
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R165 L400.35 B175 H550 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      M557 R130 S20 ; Define mesh grid
      ;Z-Probe
      M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
      M558 P5 R0.4 F1000
      G31 P100 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M350 E32 I0 ; Configure microstepping without interpolation
      M350 X32 Y32 Z32 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 E837 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S285 ; Set maximum heater temperature to 285C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
      M563 P0 D0 H1 ; Define tool 0
      M550 PLittleMonster ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S1 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      Here is bed.g
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool on Sat Oct 21 2017 14:08:18 GMT-0400 (Eastern Standard Time)
      ; Clear any bed transform
      M561
      ; Home all towers
      G28
      ; Probe the bed at 6 peripheral and 6 halfway points, and perform 7-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y149.9 H0 Z-99999
      G30 P1 X129.82 Y74.95 H0 Z-99999
      G30 P2 X129.82 Y-74.95 H0 Z-99999
      G30 P3 X0 Y-149.9 H0 Z-99999
      G30 P4 X-129.82 Y-74.95 H0 Z-99999
      G30 P5 X-129.82 Y74.95 H0 Z-99999
      G30 P6 X0 Y74.9 H0 Z-99999
      G30 P7 X64.87 Y37.45 H0 Z-99999
      G30 P8 X64.87 Y-37.45 H0 Z-99999
      G30 P9 X0 Y-74.9 H0 Z-99999
      G30 P10 X-64.87 Y-37.45 H0 Z-99999
      G30 P11 X-64.87 Y37.45 H0 Z-99999
      G30 P12 X0 Y0 H0 Z-99999 S7
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      • Vamporaundefined
        Vampora
        It does work with with a G30 executed.
        • Dougal1957undefined
          Dougal1957
          Is the distance from the bed to the nozzle tip really 550mm when homed on the Tevo seems a little high to me (I dont know the printer so not certain but based on my own Kossel XL which is 1 meter high total my homed hight is near 400mm).
          To me you are diving to low before the FW gets chance to slow down for the probe so you have 2 options.
          1 Reduce the Homed hight in the M665 line to a value much closer to what the reality says.
          2 Increase the Dive hight in the M558 line (the H param)
          or a combination of both and for initial configuration I would set the dive hight to 30 or more for the first autodial runs anyway
          HTH
          Doug
          ps one other thing I noticed is that you are doing a 7 factor cal I would change that to S6 or S8 and make sure your Rod length in the M665 is correct first.
          • Vamporaundefined
            Vampora
            I think that was part of it.
            This is the new config that works. The facebook group helped me figure out. It is working pretty well finally. Now I just have the get the prints looking a little better with the 0.8 nozzle.
            Paul Sinclair M111 S0 ; Debugging off
            ;SmartEffector
            M558 P5 R0.4 F1000 H30
            G31 P100 X0 Y0 Z-0.1
