    remove homing status when ATX power is lost
    • nraynaudundefined
      nraynaud
      Hi all,
      I would like to mark all the axes as having lost their homing when the power supply is off, either as a voltage level detection or as an interception of the ATX power cut command. I can't find a way to do it. The interception for printing resume M911 seems to explicitly kick in work when there is an SD card print running.
      I mostly want to not forget when I'm fiddling with the machine that I have lost my homing.
      thank you for your help.
      Nicolas.
        This is already on my firmware work list.
        • nraynaudundefined
          nraynaud
          I suspect the system doesn't wait for the V_IN voltage to be up after M80 has been sent, and that sent a fault on my tool heater and the program started without extruding.
