Remove heatbed from system
Hi! i need to remove heatbed from system that is duetWiFi, 2.01beta1(RTOS) (2018-06-23b1)
to do so i commented outM305 P0...:{../name}: BUT in WebUI i still see heatbed with heatbed showing 2000 degreesconfig attached 0_1531124068962_config.g
what is wrong with this config???
many thanks!!
I think you need to actively disable heater 0:M307 H0 A-1 C-1 D-1
Use M140 H-1 in config.g to tell the firmware that there is no bed heater.
@dc42 said in Remove heatbed from system:
M140 H-1
fantastic! it works! thanks!
.... and i updated wiki with that trick
