    Multi Z leveling fine tuning
    • JoduWei
      JoduWei last edited by JoduWei
      Points 0 and 2 alternate...
      Do you have an idea, what parameter could be wrong?
      Its hard to measure the z steppers position exactly relative to the bed.
      Leadscrew adjustments made: 0.130 0.102 0.086, points used 3, deviation before 0.103 after 0.000
      Leadscrew adjustments made: 0.096 0.022 0.122, points used 3, deviation before 0.088 after 0.000
      Leadscrew adjustments made: 0.129 0.099 0.072, points used 3, deviation before 0.096 after 0.000
      Leadscrew adjustments made: 0.067 0.105 0.111, points used 3, deviation before 0.099 after 0.000
      Bed.g
      G28 ; home
      M401 ; deploy Z probe
      G30 P0 X40 Y40 Z-99999 ; probe near a leadscrew
      G30 P1 X155 Y300 Z-99999 ; probe near a leadscrew and calibrate 3 motors
      G30 P2 Y40 X300 Z-99999 s3; probe near a leadscrew
      M402 ; retract probe
      config.g
      M584 X1 Y0 Z4:2:5 E3 ;
      M671 X-20:330:155 Y-105:-105:437 S4 ; leadscrews at front left, front right and rear middle
      Front is bottom. X0 and Y0 Lower-left corner of the bed
        Are you certain that the order of the motors in your M671 command is the same as the order in your M584 command? For example, the motor connected to driver 4 (the output labelled E1) should drive the leadscrew at X-10 Y-105.
        • JoduWei
          Yes I'm certain, i checked it at least 5 times.
