Connecting to Wifi via the Touch Panel?
I'm wondering if it would be possible to add the ability to connect the Duet WiFi to a network via the Duet panel. I'm envisioning being able to enter the SSID and password all from the panel. This way the printer could get on a network without having to be plugged into a computer and set up via terminal commands.
Would love to hear people thoughts on this functionality.
You can already manually enter the commands via the on screen keyboard of the PanelDue. There may be cases where special characters might be missing on that keyboard, but I'm not 100% sure.
I prefer to put the M587 SSID and Password command in a "SETNETWORK" macro which I write to the SD card using a PC, and then run the macro from PanelDue.
