    Timelapse pictures & videos with Duet and webcam on layer change
    43
    7.6k
    • wilrikerundefined
      wilriker @Hugo Hiasl
      @Hugo-Hiasl This mainly depends on the software you use to provide the stream. Some of these will allow you to have a continuous video stream that will just be paused for a second to take a snapshot image. I think both mjpg-streamer and uStreamer support this. But I have never tried it.
      Manuel
      My Tool Collection
      etrigan63undefined EasyTargetundefined 2 Replies Last reply Reply Quote 0
      • etrigan63undefined
        etrigan63 @wilriker
        @wilriker Keepalive post.
        In answer to your question, yes mjpeg-streamer can be used this way and it is how the octolapseplugin works in octoprint. I have a Vivedino Troodon (Voron-clone) and it's clone Duet2 Wifi card is so good it has the same issues with Octoprint that the OEM board suffers.
        Carlos Echenique
        3D Printers Guru
        • EasyTargetundefined
          EasyTarget @wilriker
          @wilriker
          I cant speak for ustreamer but mjpeg-streamer provides a http stream on http://<ip:port>/?action=stream and can accept multiple connections. I regularly have it streaming on my desktop and media-pc simultaneously without issues or any noticeable load on the Pi.
          OctoPrint's inbuilt timelapse system, (or octolapse , if you love needless complexity) requests snapshots via http://<ip:port>/?action=snapshot, there is no detectable pause on the streams when this is invoked.
          Conventionally: To get a timelapse you use a script to capture frames at set intervals/events, timestamp them if desired and save them. Once the capture is complete you stitch them together using ffmpeg.
          However.. when I want a timelapse on my CNC I start a screen session (nohup shell) on it's attendant Pi and run this:
          pi@laserweb:~ $ ffmpeg -r 600 -i http://localhost:8080/?action=stream  -vf "drawtext=fontcolor=white:fontsize=16:box=1:boxcolor=black@0.3:x=(w-text_w-10):y=(h-text_h-5):expansion=strftime::text='CNC \:\ %H\:%M\:%S'" -r 20 lapse.`date +%Y%m%d%H%M%S`.avi
          Which tricks ffmpeginto thinking that my 30fps stream is really a 600fps stream, and the asks it to timestamp that and convert to a 20fps framerate.
          The end result is a 20x speedup video with timestamp, but the quality is noticeably lower than the capture/assemble method. And the Pi3 is devoting 32->40% of it's CPU to ffmpeg while it is running. Not recommended as a permanent solution, it's a classic quick'n'dirty one liner.
          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
          PrintPy2024 to the rescue!
          MicroPython based; with simple wiring and and no custom PCB.
