    Delta calibration issue
    691
    • madmattco
      madmattco last edited by
      Moved away from the nozzle probe and have installed an ir sensor. but effector still dances around like its lost.
      Here is a video.
      https://www.dropbox.com/s/hwjqbqb5xor1oxb/2018-07-13 23.18.35.mov
      • Danal
        Danal last edited by
        If you hold something up to the probe, do you see the value in DWC change?
        What is your config.g G31? For example, mine is:
        G31 P1000 X0 Y0 Z18.14 ; Set Z probe trigger value, offset and trigger height
        My X and Y are zero because I run probe that attaches directly below the nozzle. My Z is 18.14 because my probe is below the nozzle. With your kind of probe, there MUST be some values in X and Y, representing the distance between the nozzle and the probe. You may also need a little bit of positive or negative Z, depending on how 'high' the probe is mounted in relation to the nozzle. Note: If you X and Y are not right, the probe will go off the bed, like at the end of your video.
        madmattco 1 Reply Last reply Reply Quote 0
        • madmattco
          madmattco @Danal last edited by
          @danal
          M558 P1 H10 F120 T9000 ; Set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X1 Y-32 Z1.0 ; Set Z probe trigger value, offset and trigger height
          M557 R110 S20 ; Define mesh grid
          • madmattco
            Yes my z-probe value will change with distance
              Delete your old deployprobe.g and retractprobe.g files from the /sys folder on the SD card.
              • madmattco
                madmattco @dc42 last edited by
                Thank you. That worked. What do I need to set to have the auto calibration figure out everything to get as specific as possible with the machine parameters?
                  dc42 administrators @madmattco last edited by
                  @madmattco said in Delta calibration issue:
                  https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                  • madmattco
                    @dc42 For some odd reason, it thinks my rod length is 1159.094mm
                      Use 6- or 8-factor calibration, so that it doesn't adjust the rod length. Check that your steps/mm is set correctly.
                      • madmattco
                        @dc42 ty again sir! shes choochin proper now
