    New firmware 2.01 beta 2 available
    Firmware installation
    16
    39
    5.4k
    • incogizmoundefined
      incogizmo @incogizmo
      @incogizmo said in New firmware 2.01 beta 2 available:
      @dc42 said in New firmware 2.01 beta 2 available:
      • On the Duet 2 Maestro, the 2 optional add-on drivers are now assumed to be TMC2224 with UART interface
      Amazing! I will have some time on the weekend to properly test this! Along with the 7th Driver pin reversal. I will report back as soon as I can.
      @dc42 got to testing it all sooner than expected. Can confirm microstepping is now applying on both addon drivers and driver 6 (7th driver) is also working as expected.
      Are there any commands or anything else I can do to help you confirm all is working as expected?
        dc42 administrators @incogizmo
        Thanks for confirming this. I can't think of any other tests needed on the expansion board at present.
          I just had a print stop on me. I think it happened when I tried to connect to the DWC from my iphone to check on the print. I had just looked at the camera and things we're going smoothly. I loaded the DWC and it wouldn't finish loading on the iphone. I went to check the printer and it was stopped sitting above the print. Heaters off and cooling down.
          M122
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet WiFi 1.02 or later
          Board ID: 08DDM-9FAM2-LW4SD-6JKF0-3SN6N-T2ZBY
          Used output buffers: 3 of 20 (10 max)
          Static ram: 28484
          Dynamic ram: 96160 of which 0 recycled
          Exception stack ram used: 328
          Never used ram: 6100
          Tasks: NETWORK(ready,328) HEAT(blocked,1192) MAIN(running,3616)
          Owned mutexes:
          Last reset 00:16:07 ago, cause: software
          Last software reset at 2018-07-20 22:02, reason: Stuck in spin loop, spinning module PrintMonitor, available RAM 5724 bytes (slot 1)
          Software reset code 0x4049 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2001ffd0 Task 0x4e49414d
          Stack: 00000008 0044509b 00008096 ffffffed 00000000 00f00000 e000ef34 c0000000 20006c94 00445195 00444f0c 61000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
          Error status: 0
          Free file entries: 10
          MCU temperature: min 36.6, current 38.8, max 40.1
          Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
          Date/time: 2018-07-20 22:19:11
          Slowest loop: 9.67ms; fastest: 0.08ms
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: mesh
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 71.55ms; fastest: 0.01ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is running
          WiFi firmware version 1.21
          WiFi MAC address 5c:cf:7f:ef:4a:74
          WiFi Vcc 3.31, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 14808
          WiFi IP address 10.10.0.63
          WiFi signal strength -36dBm, reconnections 0, sleep mode modem
          === Expansion ===
          In the console of the PanelDue I also see an error from 3 hours earlier saying Wifi reported error: incomplete write. But nothing else. I'm not sure what that would have been from.
          • DocTruckerundefined
            DocTrucker
            I'm running an earlier version of post 2.0 beta firmware (will confirm on Monday) on a Duet Ethernet/Deux5/CoreXY with three steppers for the z-axis.
            I run a bed level compensation that probes three points in the bed.g file and adjusts the screws to level the bed.
            I've a limit switch on max y (homing works fine) but found that if the coordinate in the bed.g is beyond that limit switch the system will drive the axis into the switch and then some while the stepper misses steps.
              dc42 administrators @Phaedrux
              @phaedrux said in New firmware 2.01 beta 2 available:
              Thanks for your report. Unfortunately the stack trace doesn't provide any useful data in this case. I will change it in the next beta.
                dc42 administrators @DocTrucker
                @doctrucker said in New firmware 2.01 beta 2 available:
                The coordinates of points in bed.g files are not checked against the axis limits. This is because on delta printers it is sometimes useful to probe beyond the normal bed limits.
                DocTruckerundefined 1 Reply Last reply Reply Quote 0
                  DocTrucker @dc42
                  @dc42 Probing beyond a limit switch? That behaviour should be an exception rather than norm? If this is still the case would it be more sensible to have a hard limit and print limit for the axis maximum and minimum?
                  • helluscorusundefined
                    helluscorus
                    Is it now normal for the DWC manual controls to ignore the configured the M208 maxima? I'm not using max endstops on my cartesian and now it's able to crash past the set maxima when jogging the axis around. The previously installed 2.0 release build did not allow this with the same config.
                      I'm also still finding that my first layer heights are off unless I clear the heightmap and reload it after homing Z.
                      G29 S2 			; Disable bed compensation.
                      G29 S2 			; Disable compensation again.
                      G28 Z			; Home Z
                      G29 S1 			; Load heightmap.csv and enable compensation.
                      JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                      • keyz182undefined
                        keyz182
                        I'm getting really unreliable Wifi connection on this build, DWC is disconnecting a lot. Sometimes it will be fine for an hour or so, other times it'll be constant disconnects for a few minutes at a time.
                        Not sure if it's useful or not, but here's M122 straight after reconnecting.
                        23:37:36M122
                        Board ID: 08D6M-91AST-L2MS0-6JKDD-3SJ6K-9PD5L
                        Used output buffers: 1 of 20 (14 max)
                        Static ram: 28484
                        Dynamic ram: 96524 of which 0 recycled
                        Exception stack ram used: 508
                        Never used ram: 5556
                        Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3584)
                        Owned mutexes:
                        Last reset 03:07:26 ago, cause: power up
                        Last software reset at 2018-07-21 18:21, reason: User, spinning module GCodes, available RAM 5556 bytes (slot 1)
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                        Error status: 0
                        MCU temperature: min 43.8, current 44.1, max 44.7
                        Supply voltage: min 24.0, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0
                        Date/time: 2018-07-21 23:37:35
                        Slowest loop: 10.02ms; fastest: 0.08ms
                        Scheduled moves: 248, completed moves: 248
                        Bed probe heights: -0.864 -0.912 0.269 0.131 0.069
                        Heater 0 is on, I-accum = 0.0
                        Segments left: 0
                        Stack records: 3 allocated, 0 in use
                        === Network ===
                        Slowest loop: 170.46ms; fastest: 0.08ms
                        - WiFi -
                        WiFi MAC address 5c:cf:7f:37:89:d5
                        WiFi Vcc 3.33, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 16864
                        WiFi IP address 192.168.0.183
                        WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                        === Filament sensors ===
                        Extruder 0 sensor: ok
                        === Expansion ===
                        • gtj0undefined
                          gtj0
                          Another hang in the middle of a print...
                          The Duet is taking a few seconds to respond to commands and the Duex I2C error rate is increasing.
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet Ethernet 1.02 or later + DueX5
                          Board ID: 08DGM-95BNL-MGPSJ-6JTD8-3SS6K-11XHZ
                          Static ram: 28484
                          Dynamic ram: 95760 of which 0 recycled
                          Exception stack ram used: 484
                          Never used ram: 6344
                          Tasks: NETWORK(ready,400) HEAT(blocked,1248) MAIN(running,3128)
                          Owned mutexes:
                          Last reset 01:52:46 ago, cause: reset button or watchdog
                          Last software reset at 2018-07-21 16:32, reason: User, spinning module GCodes, available RAM 6504 bytes (slot 2)
                          Error status: 0
                          MCU temperature: min 35.7, current 35.9, max 36.3
                          Supply voltage: min 24.4, current 24.5, max 24.5, under voltage events: 1, over voltage events: 0
                          Driver 5: standstill, SG min/max not available
                          Driver 6: standstill, SG min/max not available
                          Driver 7: standstill, SG min/max not available
                          Driver 8: standstill, SG min/max not available
                          Driver 9: standstill, SG min/max not available
                          Expansion motor(s) stall indication: yes
                          Date/time: 2018-07-21 18:25:42
                          Slowest loop: 185.59ms; fastest: 102.56ms
                          Scheduled moves: 109591, completed moves: 109592
                          Bed compensation in use: none
                          Bed probe heights: 0.005 -4.491 -1.857 0.000 0.000
                          Segments left: 0
                          serial is ready with "M105" in state(s) 0
                          aux is ready with "M408 S0 R26" in state(s) 0
                          === Network ===
                          Slowest loop: 167.65ms; fastest: 0.03ms
                          Interface state: 5
                          === Expansion ===
                          DueX I2C errors 33903
                          • gideonundefined
                            gideon
                            Hello, I updated the firmware today.
                            I had version 1.21, but now he has been updated to 2.01beta2 (RTOS) (2018-07-14b5).
                            at version 1.21 everything did it well but now I have 1 problem the homen of the x and y axis goes well, but if I do on the x axis +100 then he moves digionally this was not the other version
                            how can I solve this ?
                            it is about corexy, the problem in the firmware should be downgraded or I am doing something wrong
                            thank you in advance
                            is about the duet 2 v1.03
                            gideonundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • gideonundefined
                              gideon @gideon
                              @gideon I found the error by not reading properly,
                              I have put the DWC back to version 1.21R4 and now it works again
                                dc42 administrators @helluscorus
                                @helluscorus said in New firmware 2.01 beta 2 available:
                                I already asked chrishamm to revert this behaviour.
                                  dc42 administrators @gideon
                                  @gideon said in New firmware 2.01 beta 2 available:
                                  This is a bug in DWC 1.21.2beta2 used with CoreXY machines. Please revert to DWC 1.21.
                                  gideonundefined 1 Reply Last reply Reply Quote 0
                                  • gideonundefined
                                    gideon @dc42
                                    @dc42 I found the error by not reading properly,
                                    • JohnOCFIIundefined
                                      JohnOCFII @Phaedrux
                                      G28 Z			; Home Z
                                      Interesting. I noticed that I was getting a smushed first layer on parts of my delta bed with beta2. I wonder if this is related, or if my issue is just something physical. I'll have to try this to see if I see different behavior.
                                      • sjason1377undefined
                                        sjason1377 Banned
                                        this firmware doesn't let probe work. P9 code does nothing
                                          Closing this thread because nobody should be using the 2.01RC firmware now that 2.01 is released.
