Searching for suitable firmware for chartesian 3d printer
i used reprap firmware 1.09 software and it does not work successfully
the main problem is that it does not home when i touch home icon in the panel due
and another reprap version is not suitable for Cartesian 3d printer … it is mainly for delta printer
can any one recomend any recent reprap version that support Cartesian
note : my kit is duet 0.8.5
All versions of RepRapFirmware support Cartesian printers. It is the config.g file that tells the firmware whether your printer is a Cartesian or a delta.
I suggest you install either version 1.16 or version 1.17RC2, and use the tool at https://configurator.reprapfirmware.org/ to generate new config.g and homing files to suit your printer.
you should probably post your config, as well as your homing files. you can update your firmware to the latest version but it has been supporting cartesian printers for a long time. It sounds like your config.g files need work.
See: https://duet3d.com/wiki/Where_to_get_Duet_and_Duet_WiFi_firmware_and_tools
Direct link to the latest stable version: https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-0.6-0.8.5/Stable
Also download the duetwebcontrol file, it needs to be installed also.
