gcode visual during print
repetier host shows line by line code being run. Why not an option on dwc to watch code running. if you get in trouble you have the line that a pause happened visible to restart from.
This has been on my TODO list for a while but it takes some time to implement. So far I have found the following G-code visualisers that actually work:
https://github.com/jherrm/gcode-viewer
and
What do you think? Do you know any other visualisers that could be used?
I haven't tried for a while, but gcode.ws used to puke if the gcode file was larger than about 20 MB.
@chrishamm I just tested gcode.ws with a 42MB GCODE file. Worked fine (but slow).
Try gcodeanalyser.com as well.
@chrishamm https://nraynaud.github.io/webgcode/
But I still prefer gcode.ws
@chrishamm A forked version of http://gcode.ws is used in OctoPrint (the original version does not support
G2/G3
commands whereas the OctoPrint fork does). Sadly it is integrated into the OctoPrint repo and not a separate fork.
