    SAM-BA Download
    • ianlee74
      ianlee74 last edited by
      I'm trying to follow the Duet WiFi instructions to update the firmware using SAM-BA. However, the Microchip/Atmel website seems to be having problem with its login mechanism and won't let me download it… Could someone put the Window bits somewhere I can get them or send them to me?
      I've used bossac in the past to update the firmware on my Duet boards. However, it doesn't seem to recognize my Duet WiFi board despite that it appears in Device Manager as a Bossa Program Port. Is this expected?
      Thanks!
      • DjDemonD
        DjDemonD last edited by
        Ill host the file for the time being:
        https://1drv.ms/u/s!Apv79JfGbPIwgulVoRt8eCOHA4rAVQ
        www.precisionpiezo.co.uk
        • ianlee74
          @DjDemonD:
          Got it. THANKS!
            For the record, the list of processors supported by bossac doesn't include the SAM4E used on the Duet WiFi. That's why we use SAM-BA. But you should only need to use it if you press the Erase button, or if the in-application firmware update fails.
            • ianlee74
              @dc42:
              Understood. This is in relation to this thread. Formatting the SD card and updating the firmware using the web interface have so far had no effect. So, I pushed the erase button in an attempt to get everything as clean as possible.
              • Hey_Allen
                Hey_Allen last edited by
                Thank you!
                I ended up loading the new beta firmware out of order, and promptly lost contact with the board. Reloading through the card wasn't working, and eventually wasn't responding to Repetier Host to even try that route.
                I was waiting on Atmel for access to this file as well. The webmaster replied this morning after I reported the issue. She stated that they are having problems with myAtmel and asked what file I was trying to download, but then never replied after that point.
                With this, I can at least boot a windows partition and get the Duet back online.
