    homing problem with z on tevo delta
    • Reckham
      Reckham last edited by
      I have a little problem on my Tevo Delta with homing.
      z does not seem to home, but after a few seconds the motor starts. Unfortunately it does not reach the top and stops about 10cm before reaching the top. (see attached)
      My x and y axis are working fine, but z still causes problems.
      I already tried to swap my z controller to e1 (P4), but still no success.
      I have checked all wires and pinnings several times. I also crimped some again. I tried different cables. All motors are working. Amperage is fine too.
      Now the strange point: If I swap the cable e.g.: from z and y, then the problem occures on my y axis and z is fine then.
      I am running out of ideas what the problem could be.
      (btw: I am running 1.21. I upgraded too, but without success.)
      Thanks for help in advance 🙂
        I suggest you start by testing the motors individually as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually.
        When you swapped the Z and Y motor cables, did you exchange just the connectors where they plug into the Duet; or are there connectors at the stepper motor end too and you swapped the stepper motor connectors as well?
        Reckham 1 Reply Last reply Reply Quote 0
        • Reckham
          Reckham @dc42 last edited by
          @dc42 Hi,
          Thank you for the quick response! 🙂
          I tested both ways. But the motors are working fine. I already tested them seperately.
            dc42 administrators @Reckham last edited by
            @reckham said in homing problem with z on tevo delta:
            Did you test them using G1 s2 commands, as described on that page? That tests the complete motor/cable/driver/firmware configuration combination.
            • Reckham
              I tested them seperately, yes.
              G91 and then seperately.
              Z does not react. But if i swap the connector from the z motor to the y motor (cables on board stay), then the y axis does not react.
              I also tested moving my z to P4 (second extruder spot on board). Same problem.
              Might this be a board problem? Or is the problem still anywhere else?
                Do you have 2 jumpers in the unused Z motor connector?
                • Reckham
                  Fixed. Thank you very much! 🙂
                  Have a nice day 🙂
