    Change degrees C to Volts for tool tip
    Duet Web Control wishlist
    • T3P3Tonyundefined
      T3P3Tony administrators @kuhnikuehnast
      @kuhnikuehnast said in Stable firmware 2.01 (Duet 2) and 1.22 (Duet 06/085) released:
      Funny mistake I just noticed:
      If you hover over the Voltage Sensor display on the top right, the display says 12.1 V actual, Minimum: 12 °C and Maximum: 12.3 °C 🙂 But Voltage isn't temperature 😉
      greetings kuhni
      0_1532814869841_Voltage-Display-error.jpg image url)
      @chrishamm please see this bug report!
      www.duet3d.com
      • chrishammundefined
        chrishamm administrators
        Thanks! I'll fix it.
        Edit: Fixed in v1.22-b1.
        Duet software engineer
