BL Touch issues
Haha. Get some rest tiger.
To explain, one of my connections was lose and causing issues it seems. I send the G30 code and it seems to be working mostly correct except my bed goes the wrong way. I'll figure that out tomorrow.
Does the bed move the way you'd expect it to if you move it manually with the buttons? You z motor direction might need to be reversed.
Adding a minus to numbers makes it go down, yeah.
Although, on second thought that is incorrect. I think you're right. I'll have to adjust some things.
Yes in a core xy with a moving bed if z0 is nozzle touching the bed then dropping the down would increase the z value in the positive direction.
Youll have to reserve a motor direction. And ensure your maxima and minima are correct. And may need to modify the homing files if they were dropping the bed before moving in x and y.
