    Pause Print, Change Filament, Resume Print
    • Quadcells
      Quadcells last edited by
      Sounds simple, haven't tried it yet. have a question about it.
      Pause the print, I am told that the hotend will rise about 10mm, remove the filament and load the new filament.
      Before I resume the print is there anything else I need to do so not to have a blob of filament at the start of resume print or a lack of filament at the nozzle.
      This is on a delta with a Smart Effector with a Nimble extruder attached.
      Thanks in advance.
      /quadcells
      /quadcells
        dc42 administrators @Quadcells last edited by
        @quadcells said in Pause Print, Change Filament, Resume Print:
        That depends on the contents of the pause.g and resume.g files on your SD card. Did you create them yourself, or did you buy a printer or printer kit with a Duet controller installed (in which case the supplier has probably customised them) ?
        • Quadcells
          Hi dc42,
          This is a my own build. I haven't created those files yet, didn't know about those. I thought all I had to do was press the pause button on the PanelDue.
          I will look for more info on those two files.
          /quadcells
            You can put whatever GCode commands you like in those files. This is the pause.g file that I use on my Cartesian printer:
            ; Pause macro file
            M83 ; relative extruder movement
            G1 E-4 F2500 ; retract 4mm
            G91 ; relative moves
            G1 Z5 F5000 ; raise nozzle 5mm
            G90 ; absolute moves
            G1 X-105 Y95 F5000 ; move head out of the way of the print
            And this is the resume.g:
            ; Resume macro file
            G1 R1 X0 Y0 Z2 F5000 ; move to 2mm above resume point
            G1 R1 X0 Y0 Z0 ; lower nozzle to resume point
            G1 E4 F2500 ; undo the retraction that we did in pause.g
            If you were to use similar files, then if loading filament while the printer is paused you would need to allow for the fact that the extruder will extrude 4mm of filament when resuming.
            HTH David
            Quadcells 1 Reply Last reply Reply Quote 0
            • Quadcells
              Quadcells @dc42 last edited by
              @dc42 said in Pause Print, Change Filament, Resume Print:
              ; Pause macro file
              ; Resume macro file
              HTH David
              Thanks dc42, I'll work with that and see what I can do.
              /quadcells
