    heater keep faulting many time
    779
    • Sorrajakundefined
      Sorrajak
      hi
      why the heater keep faulting many time, how to fix this problem....
      ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
      ; generated by RepRapFirmware Configuration Tool on Thu Aug 02 2018 09:13:43 GMT+0700 (Indochina Time)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M550 PGiant_V3 ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80 Y80 Z640 E418.5 ; Set steps per mm
      M566 X1800 Y1800 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z600 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X500 Y400 Z400 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S1 ; Set active high endstops
      M558 P5 X0 Y0 Z0 H5 F120 T9000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P600 X0 Y0 Z0.2 ; Set Z probe trigger value, offset and trigger height
      M557 X15:485 Y15:385 S20 ; Define mesh grid
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      • dragonnundefined
        dragonn
        Did you do a PID calibration?
        • Sorrajakundefined
          Sorrajak
          problem only nozzle temp, i use e3d thermistor.
            Have you read the page on heater faults in the Troubleshooting section of the wiki?
            Sorrajakundefined 2 Replies Last reply Reply Quote 0
            • Sorrajakundefined
              Sorrajak @dc42
              @dc42 yes
              • Sorrajakundefined
                Sorrajak @dc42
                @dc42 I don't understand, sometime the heater keep faulting all day but the next day noting happen. I can print normal for couple days then it happen again. Why?
                dragonnundefined 1 Reply Last reply Reply Quote 0
                • dragonnundefined
                  dragonn @Sorrajak
                  @sorrajak is they any specific moment when the heater is going fault? Like for example the part cooling fan kicks in.
                  • deckingmanundefined
                    deckingman
                    Also check the PSU voltage. If that drops too low, it could cause the temperature to rise slower than expected. Run M122 to check.
                      The "Temperature rising too slowly" message normally only happens if you have not run PID tuning for that heater, or you did but you didn't save the results, or you saved them using M500 but you don't have a M501 statement in config.g to load the results from config-override.g.
                      I observer that your config.g file does not have ay M307 commands in it, neither does it run M501 to load possible saved results form config-override.g. So this explains why you are getting heater faults.
