    z probe error message
    • gideonundefined
      gideon
      hello, I have an error message that I can not bring home as quickly as possible, this happens
      when I z-as to home.
      I am using a Lj12-a3-4 probe,
      in which file should I search to find the error see screenshot!0_1533225826214_Naamloos.jpg
        @gideon said in z probe error message:
        Lj12-a3-4
        Looks like you're using an inductive probe but the error would indicate that it's from a servo command. Did you use a BLTouch before?
        Can you post your config.g, homeall.g homez.g retractprobe.g and deployprobe.g?
        • gideonundefined
          gideon
          i found the problem i usde befor a bltouch
            Good stuff.
            • gideonundefined
              gideon
              had forgotten that I tested a bltouch a few months ago but did not put anything back and then it does not work and then find where the fault lies
