    Error: Z probe readings not consistent
    • gideon
      gideon last edited by
      hello, I have another problem,
      if I start mesh grid compensation then he goes with probe, only if he is halfway then I get this error
      G29
      I have this in the config M558 P8 X0 Y0 Z1 H3 B1 I1 F60 T7000 A2 R0.3
      have tried different things, who is called a solution to this error
      thank you in advance
        This would indicate that the probe isn't giving readings close enough together.
        Try changing the A2 parameter to something higher like A5. This will increase the number of times it will try to probe before giving up,
        If you run G30 S-1 several times in a row what are the measurement values?
