    duet smart effector
    • chris
      chris last edited by
      I was wondering if I need 3 endstops on my delta kossel or are they not needed as i assume the smart effector acts as a z probe?
        On a delta it's possible to use stall detection homing, but only if you follow homing by at least a 4-point auto calibration cycle (e.g. using the Smart Effector as Z probe). This is because stall detect homing is accurate to +/- 1 full step at best, and on a delta a full step may be up to 0.2mm. You can do the 4-point auto calibration at the end of the homeall.g file if you want, just use the same commands that you would put in bed.g - or just use G32 if you want to perform full auto calibration.
        Stall detect homing needs to be tuned, see https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing.
        A disadvantage of using stall detect homing is that if you want to use the resume-after-power-fail functionality, you won't be able to re-home accurately when the power is restored because the print on the bed prevents you from doing auto calibration.
        • chris
          does the smart effector act as a z probe so could use it to probe bed as z min as home ?
            dc42 administrators @chris last edited by
            @chris said in duet smart effector:
            Yes, but you still need to home the 3 towers individually.
