Cancel individual part(s)
@fma said in Cancel individual part(s):
It replaces tool changing commands:
Tn
by:
; part n ; process n
Regarding Cura: AFAICT your script will replace all occurrences to
Tn
including the first one that actually really selects the tool (if it has not been selected previously) and will be inserted by Cura as the very first command (even before start codes) if you chose RRF in settings.
So you might want to also check for the start of the first layer before replacingTn
lines. -
@dc42 the script above seems to work (at least for me) reasonably well, I think I could integrate it into slic3r PE to run after the slicing is done, would you integrate it to the firmware please? It would make my life so much easier.
BTW: The gcode to end the part could be something like G84 Pn Ln (the L could be the layer to stop the object at)
@patakopecek this functionality is also being discussed here:
https://forum.duet3d.com/topic/6540/a-fairly-large-change-to-the-code/12
