    Anycubic Linear + Delta autohome issue
    • sparkymark79
      sparkymark79 last edited by sparkymark79
      3_1533574006597_config.g 2_1533574006597_homedelta.g 1_1533574006597_bed.g 0_1533574006596_config-override.g Anycubic Linear + Delta with Duet 3d and Smart Effector
      I've just returned back to this printer after a few months as I was recovering from an operation so I'm struggling to remember exactly what I did to break it.
      Basically when I press autohome, it seems like one of the axis is going down whilst the others go up. But then sometimes it looks like it is skipping back and forth. I really don't know what's wrong.
      I've made a video which I'll link (this is after pressing autohome) and I've attached the important files (let me know if I've missed an important one). Please somebody tell me where I'm going wrong.
      This only seemed to happen when I had a problem with the extruder which i mentioned on here, and I changed the stepper settings from 663 steps per mm to 96 as it looked to be incorrectly set.
      https://www.youtube.com/watch?v=wkOscl-9MJw
      Many Thanks
      Here's the config and homedelta to save you opening up the file:
      ; generated by RepRapFirmware Configuration Tool on Mon Jun 18 2018 19:57:02 GMT+0100 (British Summer Time)
      M82 ; ...but absolute extruder moves
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
      M665 R136 L288.15 B120 H217 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M587 S"---------------------- ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X80 Y80 Z80 E96 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.211 ; Set Z probe trigger value, offset and trigger height
      M557 R120 S20 ; Define mesh grid
      M106 P0 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      M501
      Home Delta:
      ; homedelta.g
      G91 ; relative positioning
      ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
      G1 S1 X355 Y355 Z355 F180 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
      ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
      G1 S1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
      • mrac1
        mrac1 last edited by
        Looks like your motor wiring is not correct. Did you checked if the motor windings match the connections on the board?
          Test the motor that is going down using G92 followed by G1 S2 moves, as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually. If that motor always goes down whether you command it up or down then there is either a bad connection in the motor cable, or possibly a blown stepper driver chip, or just possibly a blown motor.
          • streamliner
            streamliner last edited by
            Please keep in mind that the Anycubic Kossel has at least one published manual in which it indicates the motor pattern incorrectly. The pattern, if facing the machine(where the lcd is typically mounted), X is to your left. Z is in the MIDDLE, and Y is on the right upright. Another way to think about it is that starting with X on the left upright, if you go counterclockwise you'll have X -> Y > Z.
            This single error has caused so many issues for Anycubic I started writing an auto-response to people posting in the marlin github.
            I made this mistake when I originally purchased a Kossel.... but then I got pissed off at Anycubic and returned it, turned it into two Ender 3's. 😃
            Anyways, I hoep this is your issue.
            • sparkymark79
              Guys, I just performed a home perfectly.
              I had the motors set incorrectly (x>z>y) and the end stops set incorrectly - along with a loose connection on one.
              Thanks a bunch. will get to work on getting it to print later 🙂
              • streamliner
                @sparkymark79 glad that was it man.. lol, between the fb groups, forums, and github repos I regular... I have probably seen people with this problem close to a hundred times at this point.. I still have the manual with the incorrect(but seemingly correct-looking) layout.
