    Paneldue - How long can leads be?
    • Calebc
      Calebc last edited by
      I am working on large-scale, multi-axis application that requires duet board to be positioned close to end affector. I would like to mount the Paneldue on the stationary control cabinet. This will require extending the four wires that control and power the panel 5-7m. Has anyone done this successfully before or envision any problems with this? I am planning on using shielded 24ga control wire.
        The PanelDue instructions tell you that the maximum resistance per conductor should not exceed 0.1 ohm. You should check whether 24awg wire is thick enough to meet this requirement.
