Extruder clogging near end of first layer
Anycubic - genuine v6 hoteend, duet and smart effector
So I've finally got my printer printing on the new duet setup but now the extruder starts skipping near the end of the first layer. I'm guessing because the extruder is getting clogged but i suppose it's possible it's another reason.
Prior to this I increased the power on the extruder motor to 1000 (up from 800). Is this high enough or should I set it higher?
I've attached a picture of the hot end and a failed print and as per standard posted my config.g below:
; generated by RepRapFirmware Configuration Tool on Mon Jun 18 2018 19:57:02 GMT+0100 (British Summer Time); General preferences
M82 ; ...but absolute extruder moves;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R136 L288.15 B120 H217 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 PMy printer ; Set machine name
M552 S1 ; Enable network
M587 S"############; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M92 X80 Y80 Z80 E96 ; Set steps per mm
M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.232 ; Set Z probe trigger value, offset and trigger height
M557 R100 S20 ; Define mesh grid; Heaters
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
M501
; Automatic saving after power loss is not enabled -
What is the rated current of the extruder motor?
