    prints coming out slightly too small delta printer
    • dmkmedia
      dmkmedia last edited by
      I did a test print of a 20mm cube and it was 20 mm but when I go bigger a 150 mm circle is 145mm
      I'm seeing all kinds of size problems but they are only a few mm out
      how can i sort this out
      my stepper motors are
      Product Name : Stepper Motor
      Model No. : 57HS5125A4
      Frame Size : 57 x 57mm (Nema 23)
      Step Angle : 1.8
      Rated Current : 2.5A
      [https://www.amazon.co.uk/gp/product/B074CT44Z6](link url)
      my motor config is
      M350 X16 Y16 Z16 I1
      M350 E8 ; Configure microstepping with interpolation
      M92 X80 Y80 Z80 E1900 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E6 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z18000 E2400 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z100 E100 ; Set accelerations (mm/s^2)
      M906 X1200 Y800 Z800 E400 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      https://dmkitservices.com
        I suggest you print some grid lines to check whether the scaling is uniform or varies with position. Even a simple noughts-and-crosses/tic-tac-toe pattern big enough to cover the whole bed may be sufficient. If the scaling isn't uniform, the lines will be bent instead of straight. This is an indication that either the steps/mm or the configured rod length is out. You can check the steps/mm by measuring the height of a tall printed object.
        If the scaling is uniform, use M579 to correct it.
        • dmkmedia
          @dc42 said in prints coming out slightly too small delta printer:
          M579
          ok so if i am 4mm too big X and 1mm too big in Y
          how should the M579 Look
            dc42 administrators @dmkmedia last edited by
            @dmkmedia said in prints coming out slightly too small delta printer:
            M579
            That depends on how long the print was in X and Y. If it was 100mm in both directions, you would need:
            M579 X0.96 Y0.99
