    dc42 IR Differential Sensor as Endstop
    • fcwilt
      fcwilt last edited by
      For my printer the dc42 IR Differential Sensor would work well as an Z axis endstop.
      Is that possible without giving up the Z-probe input for a future Z-probe application?
      Thanks.
      Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
        Yes you can connect the IR sensor to and endstop connector. However, you may need to reduce the value of or bypass one of the output resistors on the sensor to get sufficient low-level drive.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @dc42 last edited by
          @dc42 said in dc42 IR Differential Sensor as Endstop:
          Thank you.
          I will investigate.
