    Bi-directional DC motor control without h-bridge?
    • rs4race
      rs4race last edited by
      Previously I used a h-bridge to control a dc motor forward and reverse. On a new machine I am planning to use the duetwifi with x5 expansion board to control everything. I'm interested in controlling these DC motors without the addition of an h-bridge. Is this possible? How can I accomplish this?
      Thanks,
      Jeff
        You need either an H-bridge, or a DPDT relay plus a flyback diode to protect the drive mosfet. If you use a relay then you should be careful to reduce the motor current to zero and pause a short time before reversing the motor, otherwise you will get arcing over the relay contacts.
